Multilanguage database default view problem
Hi all,
I am experiencing the following problem with DGW. I have a Source database with a default view. When I built a multilanguage template the view is not marked as default view in the template.
I understand that Lotus has built in a check that only one view can be the default view. But since these two instances of the view are simply language variants it should be possible to mark them both as default view.
This is causing me real problems since AppendDocLink requires a view to be defined as default.
Hope Lotus can correct this. Does anyone have a workaround??
Bas
