Multi value selection, wide window and retain values
How can I provide a list of options for a user to choose multiple values where the window width is fairly large and the selected options are retained?
I have tried the following
dialog list with formula using DBColumn - window not wide enough
dialog list with view - values not retained
@PickList - values not retained
Fixed width listbox with DbColumn - Customer does not like the look of this
The user needs to be able to alter the selection easily
Changes can be deletions or additions
The selection options consist of two keys concatenated together i.e. Workplace and Area
I have thought about allow the user to select Workplace first and then Area but there are times when multiple Workplaces are required
Any help much appreciated
TIA
Subject: Multi value selection, wide window and retain values
@Picklist - why aren’t the values being retained? What is retained when you use @Picklist? When I need lots of real estate, this is usually where I go.
Ditto on the Dialog list; works fine for me if I use view dialog for choice (and I get whatever view layout is defined so real estate shouldn’t be an issue).
Have you set the field to be multi-value?
Subject: RE: Multi value selection, wide window and retain values
What I mean by not being retained is that when the user next goes to the selection their choices previously selected are not selected - hence they have to select them again
From the Help
@PickList doesn’t offer a NoCache option like @DbColumn and @DbLookup because lookup results are never stored. Each time @PickList is executed, a new lookup is performed.
Dialog List with a view performs the same way
Thanks for your input
Still not clear.
Are we talking about fields that are defined as dialog lists, or buttons that present @PickList and then set a field, or something else?
If you’re setting a field value somewhere and you can see the value gets set until you move to another field (or refresh the form), then I’d look at the field translation formula - you could have code there that’s killing whatever you set.
Doug
