My workstation has two monitors. So convenient it is for the client and designer in separate monitors… oh not really!
The InfoBox won’t leave the primary monitor.
what a bummer!
what a bummer!
Subject: Multi-monitor Woes…
Sub-actions is misaligned when shown.
When an action button with one of more sub-actions is clicked, the menu pops-out in the right edge of the button… when in the second monitor (secondary)
Subject: RE: Multi-monitor Woes
What the!?
The Auto-Completion in code editor (be it LS or @Formula) pops-up in the primary display only.
It’s like miles away from the code window. lol
Subject: InfoBox and Multi-monitor
Remember – it’s all one client. Designer just adds a couple of framesets (and a couple of libraries) to the mix.
Subject: RE: InfoBox and Multi-monitor
I understand… it’s not a bug. it’s a limitation. it’s not multi-monitor aware.
… the pop-up help (tooltip) for syntax displays only in the primary monitor
Subject: RE: Multi-monitor Woes…
I had this same problem… i upgraded to Lotus 8.0 Client and that seamed to come with a half fix.
The info window/properties window can now be dragged across screens but the (pathetic excuse for) intelesense window stays on my primary monitor…
Coming from .NET i personally feel IBM needs to REHALL their entire developement environment…
They are – the Designer for 8.5 is a completely different critter.
