Multi key problem
Hi All,
Can anybody tell me how to use multiple keys to get the document handle.
I tried but gtting an error “too many keys” can anybody send some sample code.
many regards
siddu
Subject: multi key problem
The GetDocumentByKey method takes an array of keys, with each key corresponding to a sorted column in the view. Too Many Keys would seem to indicate that you have more keys than sorted columns.
