Hi
I wonder if anyone ever used the method MoveUserInHierarchyRequest of the notesadministrationprocess with success because I have searched the forums for answers, but nothing found, and I have already posted 2 post in this forum , but no reaction also.
Could this be a notes bug that is not fixed yet???
When I manually move a user in the hierarchy ( from an OU to another OU) the adminp works as planned. But when I use the MoveUserInHieratchy method in LotusScript I allways get the error message “A required certifier entry was not found in the Name and Address Book; consult the Notes Log for details on the specific entry” . So the process stops in the first phase of the moveuserinhierarchy.
I have, ofcourse, looked in the public address book for missing certifer documents but all were there. This is logic because if the certifier document was not in the addresbook then the manually moveuser action would have result also in an error. In the noteslog I can not find anything that is of any help.
I really want to find out why I receive this error message. I hope that since this version of notes someone has used this method with success, or someone that had this problem and could fix it.
I assume that my certifier documents are all correct ( the certifier name and public key) because else the manually moveuser action would also fail.
Any help will be very much appreciated!!!
Regards
