Move application by adminp using Lotus Script
Hi,I have search in Help, but didnt find anything.
I want to move applications from Server A to Server B from adminp using Lotus Script.
I want to use Lotus Script because there are 2500 to 3000 applications to be moved. So thought to make it automate.
Is there any way I can use adminp calling it from Lotus Script to move applications, copy applications and creating new replica, from Server A to Server B.
Thanks in Advanced.
Subject: Why Not
Just cluster the old and new server and then bring down the old server.
The admin client will let you make mass replica copies of the applications to the new server.
Word of advice. Make sure there are no hard coded scripts that have the old server name hardcoded.
