Hi, here is a view column value:-------
yy_str:=@Text(@Year(period));
mm:=@Month(period);
mm_str:=@If(mm<10;“0”+@Text(mm);@Text(mm));
date_str:= yy_str + “/” + mm_str;
date_str
where period is a date/time item containing date stamps like: 01/mm/yyyy
When I use a local replica everything works fine, but when I use server database view column shows an “incorrect” value ONLY when processing April docs: the result is 2005/03 instead of 2005/04.
Can anyone help?
Thanks,
Giorgio
