Monitoring HTTP using Telnet
I am trying to monitor HTTP on my externally hosted web server using Whats Up Gold.
I know this can be done using telnet and have been trying to find the right command to get the response header back with an OK.
I have tried GET / HTTP/1.1 and other variants but with no luck.
Can someone tell me the correct command that will produce a repsonse header with the expected 200 ok in it?
If this works it will be monitored very 60 seconds is there any issue with this i should know about?
Finally can port 1352 also be monitored using telnet in similiar fashion.
Andrew
Subject: Monitoring HTTP using Telnet
Ok I have since found that on an internal server this works fine. The only difference is that the internal server is R6.5 and the hosted server is R6.0X
