Modify message body with attachment
Hi,I am having a problem while modifying a mail message. I am adding an attachment in the existing mail body and trying to get it’s details. I am writing this code in PostSave event. I am getting the value of Body but I am not able to get details of the attachment.
I am using HasEmbedded to check for an attachment but this is where I am getting false as return. So my question is
  1. When we modify mail body and add an attachment where is the attachment saved?(In Body field or any other field)
If anyone has problem like this or knows any solution , please reply.
Thanking in advance.
Mandar
Subject: Modify message body with attachment
Hi Mandar,
Try using the NotesRichtextItem embedded object property.
Hi,Can you please explain more. I am attaching here my code for your reference.Please tell me if anything else to check.
IF (S43251664_MgDocument.HasEmbedded) then
Set S43251664_MgRTitem = S43251664_MgDocument.GetFirstItem(“Body”)
If(S43251664_MgRTitem.Type=RICHTEXT) Then
Forall j in S43251664_MgRTitem.EmbeddedObjects
if(j.Type=EMBED_ATTACHMENT) then
S43251664_MgCnt = S43251664_MgCnt + 1
S43251664_AttachmentName = S43251664_MgUniversalID &““& Trim(Str(S43251664_MgCnt)) &””& j.Name()
Call j.ExtractFile(S43251664_MgFilePath & S43251664_AttachmentName)
S43251664_Mgxml=S43251664_Mgxml + {}+Chr(13)
S43251664_Mgxml=S43251664_Mgxml + “”+Trim(Str(S43251664_MgCnt))+“” +Chr(13)
S43251664_Mgxml=S43251664_Mgxml + “”+j.Name()+“” + Chr(13)
S43251664_Mgxml=S43251664_Mgxml + “”+S43251664_MgFilePath & S43251664_AttachmentName+“”+Chr(13)
j.Remove
End Forall
