MIME part's Encoding not correctly recognized
Hi!I am parsing emails using the NotesMimeEntity class and came across a weird problem.
When I parse a MIME part that is encoded using base64, the Encoding property of the NotesMimeEntity object is always set to ENC_IDENTITY_BINARY instead of ENC_BASE_64.
An example MIME part that is recognized as BINARY looks like this :
--------------060007030600080307070604
Content-Type: image/gif;
name=“back.GIF”
Content-Transfer-Encoding: base64
Is there some limitation I am not aware of, or am I simply missing something ? Here is the full code I use (button in the Memo form, Logger is an home-made class that write a String to a default text file).
Thanks in advance !
Alexis
Sub Click(Source As Button)
Dim s As New NotesSession
Dim db As NotesDatabase
Dim dc As NotesDocumentCollection
Dim doc As NotesDocument
Dim mime As NotesMIMEEntity
Dim child As NotesMIMEEntity
Dim m As String
Dim myLog As New Logger
Dim workspace As New NotesUiWorkspace
Dim uiDoc As NotesUidocument
Set uiDoc = workspace.currentdocument
Set doc = uiDoc.Document
s.ConvertMIME = False
Set mime = doc.GetMIMEEntity
Call visitMimeRecursive(mime)
s.ConvertMIME = True
’ Restore conversion
Sub visitMimeRecursive(notesEnt As NotesMimeEntity)
Dim child As NotesMimeEntity
If notesEnt Is Nothing Then
	Exit Sub
If Not(notesEnt Is Nothing) Then
	If notesEnt.ContentType = "multipart" Then
		Call myLog.log("multipart, calling recursive on each child",0)
		If notesEnt.Preamble = "" Then
			p$ = "No preamble"
		Else
			p$ = notesEnt.Preamble
		Call myLog.log("Preamble : " & p$,0)
		Set child = notesEnt.GetFirstChildEntity
		While Not(child Is Nothing)
			Call visitMimeRecursive(child)
			Set child = child.GetNextSibling
		Wend
	Else
’ if not multipart
		Dim  session  As  NotesSession
		Set session = New NotesSession
		Call myLog.log("Not multipart. Content type  : " & Cstr(notesEnt.ContentType),0)
		Call myLog.log("Content subtype  : " & Cstr(notesEnt.ContentSubtype),0)
		Call myLog.log("Encoding  : " & Cstr(notesEnt.Encoding),0)
		Call myLog.log("Charset : " & Cstr(notesEnt.Charset),0)
Else
'if not MIME
	Call myLog.log("Not MIME" ,0)
