Migration problem 6.0 -> 6.5 : Dialogbox lost of focus when used with an embedded view
I have an application which works well in notes 6.0 but a big bug appeared in version 6.5 .
I have a Dialog Box with an embedded view. In 6.0 no problem but in 6.5, Notes generates a focus problem.
Actually, as soon as I click on a document in the embedded view, I cannot set focus back to fields or buttons that are on the dialogbox form. If I open the same form without using a dialog box, it reacts OK.Does somebody have a solution or idea to be proposed ??
Thank you in advance for your assistance
Subject: migration problem 6.0 → 6.5 : Dialogbox lost of focus when used with an embedded view
I have the same migration problem 5.10 > 6.03.Did you find a solution yet?
Regards
D. Ebner
Subject: I hope for an answer of the lotus team
Sorry i didn’t find anything. The last chance is in an answer of the lotus team if they know the solution…
Pat
Subject: RE: I hope for an answer of the lotus team
hi Pat,
did you ever get a response from the Lotus Team?
mads
Subject: No respons … The lotus team it ignores its users so
the next year, I will migrate all my aplication at microsoft product … :frowning:
Subject: Log a support call, this is just a forum
Subject: Good Luck, you will need it.
hi Pat,
mads
Subject: Same problem here: migration problem 6.0 → 6.5 : Dialogbox lost of focus when used with an embedded view
I am hoping 6.5.2 will fix this issue. I can say for sure that Lotus knows about the issue because a colleague of mine recreated the issue for a member of the Notes development team at LotuSphere 2004.
I’m looking for 6.5.2 every day and keeping my fingers crossed. We’re in for an application re-write if this isn’t fixed before our client upgrades.
Anybody have any news on this?
Thanks,
Jim
