Migration/Conversion Help
I’m having a problem with an agent I’m creating in LS. First, I’m not great with Script, so I’ve been trying to piece together this code. This agent will run on selected documents that have been created using “Form A”. My mission is to migrate data from “Form A” to “Form B”, then delete the field from Form A. Some of the fields have the same data type but some are RT on Form A and Text on Form B, so I’m trying to convert the data. When I’m performing the conversion to RT, I got “Object Variable Not Set”. Here’s a sample of my code:
Sub Initialize
Dim sess As New NotesSession
Dim currdb As NotesDatabase
Set currdb = sess.CurrentDatabase
Dim frm As NotesForm
Set frm = currdb.GetForm("Form B")
Dim docColl As NotesDocumentCollection
Set docColl = currdb.UnprocessedDocuments
Dim rtitem As NotesRichTextItem
Dim currdoc As NotesDocument
Dim contents As String
Set currdoc = docColl.GetFirstDocument
Do Until currdoc Is Nothing
	Set currdoc.form = frm
	Set rtitem = currdoc.GetFirstItem("Field from Form A")
	Set currdoc.Field from FormB = rtitem
	rtitem.Remove
currdoc.Field from Form B = currdoc.GetItemValue(“Field from Form A”)
	currdoc.RemoveItem("Field from Form A")
The first set of code is what I’m using for field conversion and the second set is what I’m using for fields with the same data type.
Am I on the right track?? Any assistance will be great.
