Merge Power Point Attachments
I have a view of documents that each contain a power point presentation. What I’d like to be able to do is to select several documents in the view and then run an agent that would create a new power point presentation which merges all the slides from the selected documents.
Has anyone tried anything like this before? Does it seem feasable?
Any hints or tips would be most appreciated.
Thanks,
Gareth
Subject: Getting somewhere?
OK, so I should have searched for “PowerPoint” as one word in the first place - doh!
Anyway, I’ve found some code that sounded like it is doing something similar, and I’ve adapted it slightly, but I don’t think I’m setting my “thisobj” object properly as I’m getting an “Onject variable not set” error at this line…
thisobj.Application.Visible = False
The object I’m setting before this looks like it has picked up the attachment OK.
Any ideas would be very helpful, thanks.
Full code…
Sub Initialize
Dim s As New NotesSession
Dim db As NotesDatabase
Dim col As NotesDocumentCollection
Dim doc As NotesDocument
Dim slidenum As Long
Set db = s.CurrentDatabase
Set col = db.UnprocessedDocuments
If col.Count <> 0 Then
	Set doc = col.GetFirstDocument
	Set PPAppObj = CreateObject("PowerPoint.Application")
	PPAppObj.Activate
	Set PPPresObj = PPAppObj.Presentations.Add(True)
	slidenum = 1
	PPPresObj.Saveas "C:\TEMP\test1.ppt"
	While Not (doc Is Nothing)
		If PPScript(doc, PPPresObj, slidenum) Then
			PPPresObj.Save
		Set doc = col.GetNextDocument(doc)
		slidenum = slidenum + 1
	Wend
closepres:
Exit Sub
Function PPScript(doc As NotesDocument, PPPresObj As Variant, slidenum As Long) As Integer
Dim PPObjset As Integer
On Error Goto BadError
Const DEFAULT_AUTO_LAYOUT = 16
Set rtitem = doc.GetFirstItem("PresFile")
Set object = rtitem.EmbeddedObjects(0)
Set thisobj = Object.Activate(False)
thisobj.SaveAs("c:\TEMP\temp.ppt")
thisobj.Application.Quit
Set object = Nothing
Set thisobj = Nothing
ppObjset = False
Call PPPresObj.Slides.Add(slidenum, DEFAULT_AUTO_LAYOUT)
Set SlideObj = PPPresObj.Slides(slidenum)
Set SlideShapes = SlideObj.Shapes
Call SlideShapes.AddOLEObject(100, 10, 450, 500, "", "c:\TEMP\temp.ppt", False, "", 0, "", False)
PPScript = True
Goto Ennd
BadError:
Msgbox "Error" & Err() & ": " & Error(),mb_ok, "Create Document"
Goto Ennd
ViewError:
Goto Ennd
Ennd:
PPScript = False
Enndd:
If PPObjset Then
	PPAppObj.Application.Quit
	Set PPObj = Nothing
Exit Function
End Function
