Mental Block! Help Please: View Category
Hey all,
Im having a major mental block.
I have a view that is categories by year, month and date in descending order.
In the column after the date i need to categories the task sections into 2 parts (Testing Stage One and Testing Stage Two).
The only problem is i dont think its as simple as going into the properties and selecting the categories…
as i need to to display all the most recent data under each task sections…so for instance…
2008 - April - 21/04/08 - Testing Stage One
View Record One
View Record Two
View Record Three
Etc
2008 - April - 21/04/08 - Testing Stage Two
View Record One
View Record Two
View Record Three
Etc
At present my view is displaying all the recent view records under each heading for the past 7 months and I would like to minimise this down to two sections (Test stage one and Test stage two) but showing the recent records at the top.
Hope that makes sense.
Gem
Subject: Mental Block! Help Please: View Category
Could you give more info on the way you want your data? I’m not sure if what you want is:
2008 - April - 21/04/08 - Testing Stage One ← This is Category
View Record One
View Record Two
View Record Three
Etc
View Record One
View Record Two
View Record Three
or if you would like something like this:
2008 - April - 21/04/08  <-- This is also Category
    View Record One
    View Record Two
    View Record Three
Testing Stage Two
   View Record One
   View Record Two
   View Record Three
Please give more info and maybe I can help.
Subject: RE: Mental Block! Help Please: View Category
Hi Carlos,
I really would like something like this…
2008 - April - 21/04/08 (This is categoriesed and cascades down)
Testing Stage One (I need this to be categorised i think?)
View Record One
View Record Two
View Record Three
20-/03/08 -
View Record One
View Record Two
View Record Three
19-/02/08 -
View Record One
View Record Two
View Record Three
etc
Testing Stage Two (I need this to be categorised i think?)
View Record One
View Record Two
View Record Three
20/03/08
View Record One
View Record Two
View Record Three
19/02/08
View Record One
View Record Two
View Record Three
Etc
So all the views for test stage one will be put in descending order as shown above…and then the same for test stage two…
Does that make sense?
If you want to divide documents into stage one and stage two your first category has to be exactly that. You would then have to categorize by date and you would get something like this:
Testing Stage One
2008 - April
  21/04/08 Record One
  20/04/08 Record Two
2008 - March
  19/03/08 Record One
Testing Stage Two
2008 - April
  21/04/08 Record One
  20/04/08 Record Two
2008 - March
  19/03/08 Record One
I’m not sure if that helps, but if you try and categorize the way you showed you would actually get something like this:
Testing Stage One
  View Record One
  View Record Two
Testing Stage Two
  View Record One
  View Record Two
2008 - April - 20/04/08
Testing Stage One
  View Record One
  View Record Two
Testing Stage Two
  View Record One
  View Record Two
Not what you want I think.
