Memory leak with Visual Basic code
It appears that when I am running a VB6 script to pull addresses out of a notes Address Book, the notes.exe file leaks with every call to the notes.exe application.
Below is the VB6 code.
Private Sub UserForm_Initialize()
On Error GoTo erh:
Dim m_objNotesSession As Object                 ' Actually a NotesSession
Dim objDB As Object                           ' Actually a NotesDatabase
Dim objView1 As Object                    ' Actually a NotesView
Dim objView2 As Object                     ' Actually a NotesView
Dim objView3 As Object                   ' Actually a NotesView
Dim objDocs1 As Object                            ' Actually a NotesDocument
Dim objDocs2 As Object                        ' Actually a NotesDocument
Dim objDocs3 As Object                      ' Actually a NotesDocument
Dim strAccountID As String
Dim strName As String
On Error GoTo erh:
’ CurrentDocTextBox.Value = ActiveDocument.Name
'set module level variables
Set m_objNotesSession = CreateObject("Notes.Notessession")
m_strServer = ActiveDocument.CustomDocumentProperties("ARTIServer").Value
m_strARTIFilePath = ActiveDocument.CustomDocumentProperties("ARTI").Value
If m_objNotesSession Is Nothing Then
    MsgBox "Failure to activate Notes session. " _
        & m_cstrContactTechSupport, vbOKOnly, m_cstrErrorTitle
    CCNames.Hide
    End
'get ARTI database
Set objDB = m_objNotesSession.GetDatabase(m_strServer, m_strARTIFilePath)
If objDB Is Nothing Then
    If m_strServer = "" Then
        m_strServer = "Local"
    MsgBox "There was an error locating the ARTI database " _
        & m_strARTIFilePath & " on " & m_strServer _
        & ". " & m_cstrContactTechSupport _
    CCNames.Hide
    End
' Getting the account the view
Set objView2 = objDB.GETVIEW(m_cstrViewByJobNum)
If objView2 Is Nothing Then
    MsgBox "There was an error locating '" & m_cstrViewByJobNum _
        & "' view in ARTI database " _
        & m_strARTIFilePath & " on '" & m_strServer _
        & "'. " & m_cstrContactTechSupport _
    CCNames.Hide
    End
' Getting the account the job document
Set objDocs1 = objView2.GetDocumentByKey( _
Left(ActiveDocument.Name, Len(ActiveDocument.Name) - 4))
If objDocs1 Is Nothing Then
    MsgBox "There was an error locating job document " _
        & "associated with open transcription in ARTI database " _
    CCNames.Hide
    End
' Getting the account ID
strAccountID = objDocs1.GetItemValue("AccountID")(0)
' Getting the Domino directory associated with this account
Set objView3 = objDB.GETVIEW(m_cstrViewAccount)
If objView3 Is Nothing Then
    MsgBox "There was an error locating '" & m_cstrViewAccount _
    CCNames.Hide
    End
Set objDocs2 = objView3.GetDocumentByKey(strAccountID & "^^^", True)
If objDocs2 Is Nothing Then
    MsgBox "There was an error locating account '" & strAccountID _
        & "' in ARTI database " & m_strARTIFilePath & " on '" & m_strServer _
    CCNames.Hide
    End
m_strDirectoryFilePath = Trim(objDocs2.GetItemValue("DirectoryFilePath")(0))
If m_strDirectoryFilePath = "" Then
    MsgBox "There was an error locating" _
        & " the Domino Directory associated with account '" _
        & strAccountID & "'. " & Chr(13) _
        & "Location is not set. " & m_cstrContactTechSupport _
    CCNames.Hide
    End
Set m_objAddressBook = m_objNotesSession.GetDatabase( _
    m_strServer, m_strDirectoryFilePath)
If m_objAddressBook Is Nothing Then
        & strAccountID & "'. " & m_cstrContactTechSupport _
    CCNames.Hide
    End
Set objView1 = m_objAddressBook.GETVIEW(m_cstrViewElysimUsers)
If objView1 Is Nothing Then
    MsgBox "There was an error locating the '" _
        & m_cstrViewElysimUsers & "' view in Domino Directory " _
        & m_strDirectoryFilePath & " associated with account '" _
    CCNames.Hide
    End
Set objDocs3 = objView1.GetFirstDocument
While Not (objDocs3 Is Nothing)
    strName = objDocs3.GetItemValue("LastName")(0) & ", " & _
        objDocs3.GetItemValue("FirstName")(0)
    If objDocs3.GetItemValue("MiddleInitial")(0) <> "" Then
        strName = strName & " " & _
    strName = strName & " (" & _
        objDocs3.GetItemValue("ExtIDValues")(0) & ")"
    AddressListBox.AddItem strName
    Set objDocs3 = objView1.GetNextDocument(objDocs3)
Wend
Exit Sub
erh:
MsgBox "Error: " & Str(Err.Number) & ": " _
    & Err.Description & " (" & Err.Source & "). " _
CCNames.Hide
End
Subject: Memory leak with Visual Basic code
Any particular reason why you’re using the old OLE (late binding) calls rather than the COM interface? The COM interface has superceded the OLE (which hasn’t seen any work since the COM interface was introduced). Please note that there’s no reason to go through the Lotus Notes Automation Objects unless you need to manipulate the Notes client UI. The COM interface (Lotus Domino Objects) doesn’t suffer from quite the same problems and is a lot more stable.
Start by adding a reference to the Lotus Domino Objects, and get your session as Lotus.NotesSession. (You can declare the actual types instead of Object.)
Subject: RE: Memory leak with Visual Basic code
Hi Stan,
I am not familiar with the COM interface. I have recently been given this code to see if I can figure out why it is leaking memory. I am fairly new to programming, but I offered to take a look at the code.
Is there anywhere you could point me to learn more about Lotus Domino Objects and the COM interface?
Thanks,
Andrew
Designer help would be a start. Simply search for COM and you should find some introductory documents.
There’s also a Redbook on that topic. Not exactly new, as it was published back in the R5 days (and I don’t think it has been updated since), but most of it should still hold true.
Also Microsoft should have lots of info on COM in general on MSDN. OK, this is a guess on my part, but I’m pretty confident, they have.
With COM you have no access to the NotesUI classes like you did with OLE, but you’re not using them. Apart from that, the basic difference is that you don’t use CreateObject for COM, but you do probably have to tell VB to add the Domino objects to your project so it can set up the binding (it’s been a while since I touched VB, so no I can’t help with details on that). And there’s an initialize() method for NotesSession that you call with COM. Apart from that, there are various differences, mostly minor. Search the Domino Desginer help database for “Accessing the Domino Objects through COM”. That will take you to a page with links to lots of useful info, includign two docs that are very useful, titled “General Exceptions to LotusScript Specifications” and “Specific Exceptions to LotusScript Specifications”.
