Meeting Creation-Note Item Not Found-Exhausted
I think this topic is exhausted (so am I) but I just can’t figure this out…I am trying to automate creating a meeting and sending it out to others. I am using VB.net, Interop.Domino.dll, and Lotus Client. The below code sends out the meeting invite, but when the invitee tries to accept the meeting a message box pops up with the error “Note item not found”, which provides little direction. I looked over several other threads and can’t get the right combination of fields to make this work…any help is appreciated and I can’t get approval to use something like Proposion…Plus, I think this should work…Thanks…
Dim _NotesSession As NotesSession
Dim _localDatabase As NotesDatabase
Dim _appt As NotesDocument
Const pwd As String = "XXXX"
Dim startTime As NotesDateTime
Dim startDate As NotesDateTime
Dim endTime As NotesDateTime
Dim endDate As NotesDateTime
Dim tmStamp As NotesDateTime
'testing addresses
Dim arrEmails(2) As String
Private Sub btnParse_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles btnAppt.Click
    'initialize Notes session
    _NotesSession = New Domino.NotesSessionClass()
    _NotesSession.Initialize(pwd)
    _localDatabase = _NotesSession.GetDatabase("", "mail\ppaasch.nsf", False)
    'test email addresses
    arrEmails(0) = "pat.paasch@domain.com"
    arrEmails(1) = "paaschpa@domain.com"
    Try
        _appt.ReplaceItemValue("$PublicAccess", "1")
        _appt.ReplaceItemValue("Chair", "CN=Pat Paasch/OU=SMGDM/OU=US/OU=AMERICAS/O=PUBGROUPE")
        _appt.ReplaceItemValue("SEQUENCENUM", 1)
        _appt.ReplaceItemValue("UpdateSeq", 1)
        _appt.ReplaceItemValue("$CSVersion", "2")
        _appt.ReplaceItemValue("$SMTPKeepNotesItems", 1)
        _appt.ReplaceItemValue("$CSWISL", "$S:1,$L:1,$B:1,$R:1,$E:1,$W:1,$O:1,$M:1")
        _appt.ReplaceItemValue("WebDateTimeInit", "1")
        _appt.ReplaceItemValue("OrgTable", "C0")
        _appt.ReplaceItemValue("STARTDATETIME", "07/20/2007 11:00:00 AM")
        _appt.ReplaceItemValue("EndDateTime", "07/20/2007 01:00:00 PM")
        _appt.ReplaceItemValue("$CSTrack", "Sent")
        _appt.ReplaceItemValue("RequiredAttendees", "paaschpa@gmail.com")
        _appt.ReplaceItemValue("Principal", "CN=Pat Paasch/OU=SMGDM/OU=US/OU=AMERICAS/O=PUBGROUPE")
        _appt.ReplaceItemValue("altPrincipal", "CN=Pat Paasch/OU=SMGDM/OU=US/OU=AMERICAS/O=PUBGROUPE")
        _appt.ReplaceItemValue("CalendarDateTime", "07/20/2007 11:00:00 AM")
        _appt.ReplaceItemValue("$NoPurge", "07/20/2007 01:00:00 PM")
        _appt.ReplaceItemValue("$BusyName", "CN=Pat Paasch/OU=SMGDM/OU=US/OU=AMERICAS/O=PUBGROUPE")
        _appt.ReplaceItemValue("BusyPriority", "1")
        _appt.ReplaceItemValue("_ViewIcon", 158)
        _appt.ReplaceItemValue("ExcludeFromView", "A,S")
        _appt.ReplaceItemValue("Logo", "stdNotesLtr0")
        _appt.ReplaceItemValue("From", "CN=Pat Paasch/OU=SMGDM/OU=US/OU=AMERICAS/O=PUBGROUPE")
        _appt.ReplaceItemValue("$FromPreferredLanguage", "en-US")
        _appt.ReplaceItemValue("altChair", "CN=Pat Paasch/OU=SMGDM/OU=US/OU=AMERICAS/O=PUBGROUPE")
        _appt.ReplaceItemValue("AppointmentType", "3")
        _appt.ReplaceItemValue("Alarms", "1")
        _appt.ReplaceItemValue("Subject", "New Test")
        _appt.ReplaceItemValue("StartTime", "11:00:00 AM")
        _appt.ReplaceItemValue("EndTime", "01:00:00 PM")
        _appt.ReplaceItemValue("StartTimeZone", "Z=6$DO=1$DL=3 2 1 11 1 1$ZX=20$ZN=Central")
        _appt.ReplaceItemValue("EndTimeZone", "Z=6$DO=1$DL=3 2 1 11 1 1$ZX=20$ZN=Central")
        _appt.ReplaceItemValue("Repeats", "")
        _appt.ReplaceItemValue("Location", "Some Room")
        _appt.ReplaceItemValue("RoomToReserve", "")
        _appt.ReplaceItemValue("Resources", "")
        _appt.ReplaceItemValue("OnlineMeeting", "")
        _appt.ReplaceItemValue("MeetingType", "1")
        _appt.ReplaceItemValue("Presenters", "")
        _appt.ReplaceItemValue("OnlinePlaceToReserve", "")
        _appt.ReplaceItemValue("Categories", "")
        _appt.ReplaceItemValue("SchedulerSwitcher", "1")
        _appt.ReplaceItemValue("$WatchedItems", "$S,$L,$B,$R,$E,$W,$O,$M")
        _appt.ReplaceItemValue("StartDate", "07/20/2007")
        _appt.ReplaceItemValue("EndDate", "07/20/2007")
        _appt.ReplaceItemValue("SendTo", "paaschpa@domain.com")
        _appt.ReplaceItemValue("body", "some body text")
        _appt.ReplaceItemValue("StartTime_2", "11:00:00 AM")
        _appt.ReplaceItemValue("StartDate_2", "07/20/2007")
        _appt.ReplaceItemValue("EndDate_2", "07/20/2007")
        _appt.ReplaceItemValue("EndTime_2", "01:00:00 PM")
        _appt.ReplaceItemValue("DispDur_1", "")
        _appt.ReplaceItemValue("DispDur_2", "")
        _appt.ReplaceItemValue("DispDuration_1", "")
        _appt.ReplaceItemValue("tmpStartTime_local", "07/20/2007 11:00:00 AM")
        _appt.ReplaceItemValue("Form", "Appointment")
        _appt.ReplaceItemValue("tmpAction", "2")
         _appt.ReplaceItemValue("tmpWasMailed", "1")
        _appt.ReplaceItemValue("orgState", "X")
        _appt.ReplaceItemValue("ApptUNID", _appt.UniversalID)
        _appt.ReplaceItemValue("tmpOwnerHW", "1")
        _appt.ComputeWithForm(True, False)
        _appt.Save(True, True, False)
        _appt.Send(False)
    Catch ex As Exception
        _localDatabase = Nothing
        _NotesSession = Nothing
    End Try
Subject: Meeting Creation-Note Item Not Found-Exhausted
Best I can do for you is to show some code I have in LS that does roughly what you’re trying to do (except the notice is an update to existing meeting, not a new one)
HTH
With docNotice
		.form="Notice"
		.AppointMentType="3"
		.Categories=iwnote.Categories
				.Repeats=""
		.MailOptions=""
		.tmpOEMClient=""
		.NoActionBar="1"
		.chair=iwnote.Chair(0)
		.Broadcast="1"
		.Topic=iwnote.Subject(0)
		.ApptUNID=iwNote.UniversalId
		.SequenceNum=iwNote.SequenceNum(0)+1'HKMar29 leapfrog
		Select Case lAction
		Case 512
			.NoticeType="U"
			.Subject=subPrefix+iwNote.Subject(0)+ suffix
			Call docNotice.replaceItemValue("_ViewIcon",33)
		Case 256
			.NoticeType="C"
			Call docNotice.replaceItemValue("_ViewIcon",81)
		Case 8192
			.NoticeType="S"
			.OrgStatus="5"
			Call .removeItem("NoActionBar")
			Call .removeItem("tmpNoActionBar")
			'Call docNotice.replaceItemValue("_ViewIcon",0)
		End Select
		.StartDateTime=dtStartDateTimePrev.lslocaltime
		.EndDateTime=dtEndDateTimePrev.lslocaltime
		.StartDate=dtStartDateTimePrev.lslocaltime
		.EndDate=dtEndDateTimePrev.lslocaltime
	End With
	Call docNotice.replaceItemValue("$RefOptions","1")
	Call docNotice.makeResponse(iwNote)
	docNotice.SendTo=pList
	Call iwNote.removeitem("iwtmp1")
	Call iwNote.removeitem("iwtmp2")
	Call iwNote.removeitem("iwtmp3")
	Call docNotice.send(False)
	Set docNotice =Nothing 														'Destroying the old invitation document
