After upgrading to meetings 11.5 premium, Audio video is not working anymore for external users
I can see thes errors messages in the jvb log and the user is dropped from the meeting
[33;1mjvb_1 |[0m INFO: Pair failed: 192.168.32.10:10000/udp/host -> 169.254.95.138:60353/udp/host (stream-7fbac65a.RTP)
[33;1mjvb_1 |[0m Nov 16, 2020 8:02:01 AM org.jitsi.utils.logging2.LoggerImpl log
[33;1mjvb_1 |[0m INFO: Pair failed: 192.168.32.10:10000/udp/host -> 169.254.65.141:60354/udp/host (stream-7fbac65a.RTP)
[33;1mjvb_1 |[0m INFO: Pair failed: 192.168.32.10:10000/udp/host -> 169.254.14.249:60355/udp/host (stream-7fbac65a.RTP)
This is strange because the ip 169.254.*.* do not belong to my private nor my public network
Any idea?
169.254.65.141 is not a valid IP, and indicates a network issue
"169.254.x.x: This is what's called an Automatic Private IP address. An IP in this range means that the computer cannot see the network. A computer using DHCP needs to have an external server tell it what IP address to use. Unfortunately, if there's no network connectivity, the computer is unable to talk to the server. In those cases, the computer will actually give itself an IP starting with 169.254, since it must assign itself some sort of number. When you see a 169.254.x.x address, you definitely have a problem. It could be as simple as an unplugged network cable, or it could be as complex as the network being down. A fair amount of troubleshooting is involved at this point, but the bottom line is that your computer doesn't even see the network."
Thank you jesper.
The problem is that the 192.168.32.10 ip does not belong to my network too.
the 169 address is the client(s) IP address.
The 192. address is what the server is advertising as its public IP.
Look further back in teh JVB logs - look for "discovered" or "discovery" and see what is being returned as the public IP from STUN.
What do you have set for the DOCKER_HOST_ADDRESS?
Hi Anthony,
I set the DOCKER_HOST_ADDRESS to the linux host private ip. I tried to change to it's public address but with no sucess.
The host address is 192.168.1.41 in the private LAN.
The docker0 IP is 127.17.0.1 and the ip affected to sametime services are:
/meetings_jvb_1 - 192.168.128.11
/meetings_jicofo_1 - 192.168.128.10
/meetings_jigasi_1 - 192.168.128.9
/meetings_nginx_1 - 192.168.128.7
/meetings_catalog_1 - 192.168.128.8
/meetings_auth_1 - 192.168.128.4
/meetings_jibri_1 - 192.168.128.3
/meetings_prosody_1 - 192.168.128.6
/meetings_jibri-web_1 - 192.168.128.5
/meetings_recordings_1 - 192.168.128.2
I do not see any information regarding the stun public ip server in the jvb log. The only thing I see is:
jvb_1 | Nov 16, 2020 3:11:11 PM org.ice4j.ice.harvest.AbstractUdpListener <init>
jvb_1 | INFO: Initialized AbstractUdpListener with address 192.168.112.9:10000/udp. Receive buffer size 212992 (asked for 10485760)
jvb_1 | Nov 16, 2020 3:11:11 PM org.ice4j.ice.harvest.SinglePortUdpHarvester <init>
jvb_1 | INFO: Initialized SinglePortUdpHarvester with address 192.168.112.9:10000/udp
2 things -
1) If you need this to work with external users, STUN must be accessible and an appropriate public IP (with ports open) must be returned
2) It looks like the DOCKER_HOST_ADDRESS is over-riding the STUN harvest. Lets remove the DOCKER_HOST_ADDRESS so that this process can work. DOCKER_HOST_ADDRESS will be 'blank' in the majority of cases.
Solved. It was an issue with my router/firewall.
Please share the issue and how you fixed it. So people who fell in the same trap and search for the symptoms can find you solution!
