Max size for purge interval?
Hi All
I want to increase the length of time for the before deletion stubs are purged from a database - but the biggest figure I can add in the field Remove docs not Modified in the last… days is 999. As you only get a third of this thats only about a years worth of deletion stubs. Due to massive problems with old data coming back I would like to keep the stubs for ever - is there any way to do this - or at least enter a bigger value?
Many thanks for any suggestions
