Math problem
I have a form with fields that is doing some calculations based on the persons job. First they fill in a checkbox with x alternativs. Then I do a calculation on it (@Elements(EdSteps))
On a other field I sum up some number from other fields in the form.
Finally I take field 1 and multiplicate this with field 2.
The problem is that when I change field 1 (checkbox) it doesnt update the sum field. If I change to division the field is updated.
Subject: Math problem
Mats,
I’m not 100% clear about your description, but try turning on “refresh fields on keyword change”. Does that help?
regards,
raphael
Subject: RE: Math problem
That is on. I have several fields that are doing calculations on the form and all of them are doing the job.
That’s strange. What I would take a second look at are the following:
  • the result field is a computed numeric field.
  • make sure the checkbox field has the “refresh fields on keyword change” property checked
Hope that helps.
