I have written the script below to create response document but it keep on pop out error message “Object variable not set” when in run until this line
“Call doc.MakeResponse(pdoc)”
Can anyone please help to check what has caused the problem ? Thanks in advance.
Dim ss As New NotesSession
Dim db As NotesDatabase
Dim uidoc As NotesUIDocument
Dim doc As NotesDocument, pdoc As Notesdocument
Set db = ss.CurrentDatabase
Set adoc = uidoc.Document
createby = adoc.Createby(0)
createdate = adoc.Date(0)
docid = adoc.DocumentID(0)
id$ = Cstr(docid)
Set pdoc = db.GetDocumentByID(id$)
doc.Form = “Response Form”
doc.Createby = createby
doc.Date = createdate
Call doc.Save(True, False)
Subject: Make Response Problem
It just the typo mistake…if you read out the line in your code…“Set adoc - uidoc.Document Createdby = adoc.Createby(0)”
Here you have declated adoc as NotesDocument and you are using doc further down the code…correct the mistake…and your error will get resolved.
Kaushal.
Your code
assumes that pdoc is found. You should protect your use of pdoc with the test
if not pdoc is nothing then
Subject: RE: Make Response Problem
Yes… I found that the system cannot find the pdoc in the database. How come the document cannot be found since we already specified the id?
Ching Chee,
In order to answer that question I would have to know how the DoucmentID field on adoc got its value. There are 3 possible causes that I can think of.
The note referenced by DoucmentID has been removed.
The note referenced by DocumentID never existed.
The database is corrupt.
