HI ALL
I have a problem of sending mails
i mail view from that i ill check the date if date is todays date then that mail shd go as alink to assined person
then it go to second document same process
problem is mail is going but i m using while loop because of this
for 1st person 1 mail 2nd erson 2mails 3 rd perwon 3 mails on son…
how to over come this…
Subject: mailing problem
Could you show us the code ??
Subject: RE: mailing problem
Sub Initialize Dim ss As New NotesSession
Dim db As NotesDatabase
Dim doc As NotesDocument
Set db=ss.CurrentDatabase
Dim view As NotesView
Set view =db.GetView ("NM")
Dim maildoc As New NotesDocument (db)
Dim maildoc1 As New NotesDocument (db)
Dim rtf1 As New NotesRichTextItem(maildoc1,"body")
Dim rtf As New NotesRichTextItem (maildoc,"body")
Dim style As NotesRichTextStyle
Set style = ss.CreateRichTextStyle
Dim datetime As New NotesDateTime ("today")
Dim level2date As String ,status As String
Dim level3date As String ,currentdate As String
Dim level4date As String ,test1 As String
Dim level1date As String ,mailname As String
currentdate=datetime.LSLocalTime
Set doc=view.GetFirstDocument
While Not doc Is Nothing
Dim keys( 1To 6) As String
keys(1)=doc.txt_app1(0)
keys(2)=doc.txt_app2(0)
keys(3)=doc.txt_app3(0)
keys(4)=doc.txt_app4(0)
keys(5)=doc.txt_app5(0)
keys(6)=doc.txt_cname(0)
status=doc.txt_status(0)
level1date=doc.dat1(0)
level2date=doc.dat2(0)
level3date=doc.dat3(0)
level4date=doc.dat4(0)
test1=doc.test1(0)
'this mailing code for escalation users
style.Bold =True
style.NotesColor =COLOR_BLUE
Call rtf.AppendStyle(Style)
Call rtf.AppendText ("Dear")
Call rtf.AddNewline (2)
Call rtf.AppendText (doc.txt_app2(0))
Call rtf.AddNewline (4)
style.Bold =True
Style.NotesFont = FONT_COURIER
style.NotesColor =COLOR_RED
Call rtf.AppendText ("The Following Complaint Details Are Still Pending From ........")
Call rtf.AddNewline (1)
style.Bold =True
style.NotesColor =COLOR_BLACK
Call rtf.AppendText ("%-------------------------------------------------------------------------------------%")
Call rtf.AppendText ("Complaint Raised Date:- "+" "+doc.txt_dat(0))
' Call rtf.AppendText ("From Past "+ " "+"Complaint is Still Pending")
' Call rtf.AddNewline (1)
Call rtf.AppendText ("Please Find Out the Status OF the Complaint As early As possible")
Call rtf.AddNewline (3)
style.Italic=True
Call rtf.AppendDocLink (doc,"")
Call rtf.AppendText ("<==Click Here To Open The Document Details..")
style.Bold =True
style.Bold =True
Call rtf.AppendText ("Thanks & Regards")
Call rtf.AppendText (doc.txt_cdept(0)+" "+"Department")
Call rtf.AppendText (doc.txt_cloc(0)+" "+"Location")
'end escalation mailing code
'bcc mails for previous levels and requestor..
Stop
'end bcc mails for previous levels and requestor..
If test1=currentdate And doc.txt_status(0)<>"Closed" Then
maildoc.form="memo"
maildoc.subject=doc.txt_cloc(0)+" "+ "Location "+"Ticket "+" "+doc.txt_isnum(0)+" "+"is Still Pending"
If keys(2) <>"" Then
maildoc.sendto=keys(2)
If level3date=currentdate And status<>"Closed" Then
maildoc.form="memo"
If keys(3) <>"" Then
maildoc.sendto=keys(3)
If level4date=currentdate And status<>"Closed" Then
maildoc.form="memo"
If keys(4) <>"" Then
maildoc.sendto=keys(4)
If level5date=currentdate And status<>"Closed" Then
maildoc.form="memo"
If keys(5) <>"" Then
maildoc.sendto=keys(5)
maildoc.Send (0)
Set doc=view.GetNextDocument (doc)
Wend
Hi reddy.I just take a look to your code, and i think that you can try this.
In this line :
If If level5date=currentdate And status<>“Closed” Then
you are asking for a no declared and intialized variable…
You are append lines to the rtm item in the middle of the while statement … maybe you could do part of it outside of the while or initilize the body item each time, i think that this make a duplicated body to send the second time, the third… you know?.
