I’m having problems using the load convert command to update users mailfiles to R6.5 template. I used -s to upgrade a users mail file, and got a bunch of replication conflicts in the inbox, any suggestions?
Subject: Mail conversion problems
This can happen if the user has the mail file open in the Notes client when the convert utility runs.Should be able to clear it by closing and opening the mail file.
Subject: RE: Mail conversion problems
Thanks and i found a way to convert the folders using the -u switch to the inbox design
