Mail Body Problem
All ,we are writing a agent and it triggers the email .in email we are giving the link . we want this as the Hyperlink. we have hard code this link like “httP//www.google.com” , it is coming fine But hyperlink is not coming .But when we open the mail and save the mail then ordinary link become the hyperlink.
I am not finding why on saving the mail , hard code link become hyper link . can anyone help on same
Regadrs
Mike
Subject: Mail Body Problem
Hi Mike
If you copied and pasted the link into your post then have you noticed that you are missing a “:” after http?
your link should be:
“http://www.google.com”
If the one in your email is correct then obviously the problem is somewhere else. Some software ‘react’ to the www.Domain.com which may be why that after saving you get the link.
If the mail is html based rather than text, then you could try the full html notation:
www.google.com
Good luck
B
http://www.Internet-Marketing-Wizards.com
