I’ve downloaded the LSXLDAP code from the Sandbox and installed in on a R6 server. It’s working fine except that it doesn’t return the FullName field from the R5 Domino LDAP server. Is there something I need to do on the LDAP server to enable it to return the FullName field??? Thanks in advance.
Subject: LSXLDAP problem
You can get all the entries in the Domino Fullname field via the LDAP cn attribute.
