Hi Everyone,
I have a form which has a “Retired” button. When a user selects this button I am wanting the status of that document to be set to “Retired”, but also at the same time I’m wanting it to check a view for any documents which have the same RegMark (Registration) as the current document and to set that/those status to Retired as well.
The only other thing I need to take into account is a field called RegMark_1. RegMark or RegMark_1 will have a value on this particular document where the Reject button is. But… on the other documents, held in the view, the field will only be called RegMark.
Can anyone help? I think I’ve gone down the wrong road, by using GetDocumentByKey ? I’m not sure.
Thanks in advance
Hayley.
Here is the code:
Sub Click(Source As Button)
Dim db As NotesDatabase
Dim doc As NotesDocument
Dim uidoc As NotesUIDocument
Dim view As NotesView
Dim vehicledoc As NotesDocument
Set db=session.CurrentDatabase
Set doc=uidoc.Document
Set view=db.GetView(".vwRVMCF")
uidoc.EditMode = True
If uidoc.FieldGetText( "RegMark" ) <> "" Then
Set vehicledoc=view.GetDocumentByKey(doc.RegMark(0),True)
Call vehicledoc.FieldSetText("Status", "Retired")
Else
RMark1 = uidoc.FieldGetText("RegMark_1")
Call uidoc.FieldSetText("RegMark", "RMark1")
Call uidoc.FieldSetText("Status", "Retired")
Call uidoc.Save
Call uidoc.Close
