LS on the Web - need help with enclosed code
Help! I need to get the following LS code to work on the web - any ideas on how to get it to work?
Function CreateRFSPMTid (session As Notessession, Source As Notesuidocument)
Dim db As notesdatabase
Dim num As Double
Dim numchar As String
Dim numprefix As String
Dim view As notesview
Dim servername As String
Dim doc As notesdocument
Set db = session.currentdatabase
servername = Mid(db.server,4,8)   ' Get server name to lookup prefix for request number.
If servername = "" Then   ' Local, set to all 0's
	source.document.RFSPMTID = "00000000"
Else
	Set view = db.getview("AdminLookup")
	Set doc = view.getdocumentbykey("Server ID " & servername)
	If doc Is Nothing Then
		numprefix = "XX"
	Else
		numprefix = doc.Listvalues(0)
	Randomize   ' Seed the random number generator
	num = (999999 * Rnd())
	num = num \ 1
	numchar = Right(("00000" & Cstr(num)),6)     ' Pad left with zeros to make 6 character number.
	numchar = numprefix  & numchar                   ' Prepend number with server id
’ Now check for duplicate
	Set view = db.getview("LookupRequestNumber")
	Set doc = view.getdocumentbykey(numchar)
	If Not doc Is Nothing Then       'If number already exists, then generate another random number
		num = num \ 1
	Set doc = view.getdocumentbykey(numchar)   ' See if the random number already exists.
	If Not doc Is Nothing Then  'If the second random number exists too, then send note to admin and proceed.
		'Call Send_duplicate_message(db,numchar)
	source.document.RFSPMTID = numchar
End Function
Subject: LS on the Web - need help with enclosed code
Laura,
Your code would need to run in a WebQuerySave event (or be in an agent called by this event) in your form and then since NotesUIDocument does not apply, your first lines of code would be…
Dim s As New NotesSession
Dim doc As NotesDocument
Set doc = s.DocumentContext
…where doc is a handle to the web doc submitted by the web user. Everything else can pretty much remain as is.
Ken
Subject: Not really. db.Server will be “” in every case. A WQS agent runs locally.
You need to use NotesSession.UserName to get the servers name. You can also do away with the Random stuff.Use @Unique instead.
e = Evaluate(|@Unique|)
numchar = numprefix  & Right(e(0), 6)                  ' Prepend number with server id
