LS not working ...help
Hi all,I have a error handling code that I have copied from this forum to help me debug my LS online and it is reporting something that I don’t understand. The code seems to work correctly (change of status and background emailing) except for the error message that gets printed on the page (as follows). The system is obviously picking up an error but I don’t know what it is and want avoid this error msg when the users will start using this. Can anyone help me figure out what the issue is?
Thanks,
Dan
OOPS …
An error has occured in the application.
Please report the following message to the system administrator:
Code - 0: . (on line 0.)
Click here to return: RETURN
Agent code lanched from the WebQuerySave event of form (@Command([ToolsRunMacro]; “(SubmitWhseDelivery)”)):
Option Public
Use “ErrorHandlingSL”
Dim topicview As String
Dim note As notesdocument
Dim db As notesdatabase
Dim maildb As notesdatabase
Dim favorites As String
Dim currentUser, currentUserEMail As String
Dim categoryview As String
Dim archivingview As String
Dim authorview As String
Dim originalnote As notesdocument
Dim Delivered As String
Dim DeliveryDate As String
Dim WONum As String
Dim Division As String
Dim JobNum As String
Dim DocAuthor As String
Dim st As String
Dim MailSubject As String
Dim MailTag As String
Dim MailTag2 As String
Dim OriginalUNID As String
Dim SendList As String
Dim WOSendList(1) As String
Dim SendListAll As Variant
Dim s As notessession
Dim SendListTrack() As Variant
Dim SendListTrackd() As Variant
Dim ShippingAgent As String
Dim AlertType As String
Dim partialflag As String
Dim Path As String
Dim activitylog
Dim activitytag As String
Dim debugCode As Integer
Sub Initialize
On Error Goto GenErr
Set maildb = New Notesdatabase("","MAIL1.BOX")
Set s = New NotesSession
Set db = s.CurrentDatabase
Set note = s.documentcontext
path=db.filepath
'-- set to 1 to debug via msgbox at server console
debugCode=0
'-- Get Doc fields
OriginalUNID = note.DocUnid(0)
SendListAll="admin@corp.com"
WONum=note.WONumber(0)
Division=note.Division(0)
JobNum=note.GPJobNumber(0)
Delivered = note.Delivered(0)
DeliveryDate=note.DeliveredDate(0)
docAuthor=note.Author(0)
currentUserEMail=note.AuthorEMail(0)
partialflag=""
'-- Generate PO Number
If note.WONumber(0)="-Not Assigned-" Or note.WONumber(0)="" Then Call SetWONum(db,note)
'-- Build logic for e-mail
st=note.Status(0)
'== CHECK STATUS
If debugCode=1 Then Msgbox st
Select Case st
Case "Draft"
	Exit Sub
'-- look if WO has been set to *Submitted* and set flags/email --
Case "Submitted"
	note.DateSubmitted=Now
'-- Generate WO Number
	activitytag=" Warehouse Order Submitted"
	Call UpdateActivity(activitytag)
	MailSubject= "The following document was " & st & ": WO#" & note.WONumber(0)
	MailTag="This WO has just been submitted. "
	MailTag2="Please follow link to view submitted Warehouse Order :"
	AlertType="Initial"
	Call SendMail_WOGroup(AlertType)
	Call SendMail_Issuer(AlertType)
	'Exit Sub  ' if status=submitted then no need to go further
	'-- look if WO has been set to *Cancelled* and set flags/email --
Case "Cancelled"
	note.DateCancelled=Now
	activitytag=" Cancelled WO"
	MailTag="This WO has been cancelled for the following reasons:" & note.RejectReasons(0)
	MailTag2="Please follow link to view WO:"
	AlertType="Initial"
	'-- look if WO has been set to *Closed/Delivered to Customer* and set flags/email --
Case "Closed/Delivered to Customer"
	activitytag=" Delivery Date established - Warehouse Delivery Order closed"
	MailTag="This WO has been delivered and closed.:"
	AlertType="Delivered/Closed"
	Call SendOrderClosedMail(AlertType)
End Select
	'-- Do the e-mail for order confirmation & arrived at warehouse
If partialflag <>"1" Then Call logStatus
'-- get path (local is for debug)
If db.Server="" Then
	p=note.ThisDBW(0)
Else
	p=Path
GenErr :
Print "<BR><BR>OOPS ... <BR>"
Call PrintErrorMsg( "Code - " & Str(Err) & ": " & Error$ + ".  (on line " & Str(Erl) & ".) ", True)
Exit Sub
Sub SetWONum(db As notesdatabase,note As notesdocument)
'==Do initial check for new docs only
If debugCode=1 Then Msgbox "Set Delivery WO Number"
Dim vcoll As NotesViewEntryCollection
Dim entry As notesviewentry
Dim view As notesview
Set view=db.GetView("vLookupDelWODoc")
sstring="WO"
'==Get all entries for that company shortcode in view
Set vcoll=view.GetAllEntriesByKey(sstring,True)
'== Count entries and set default if none found
numdocs=vcoll.count
If numdocs=0 Then
	msg="Generating Initial Warehouse Delivery WO Number ..."
	Print msg
	If debugCode=1 Then Msgbox msg
	nextnumber="1000" '1000 is number of 1st WO
	Goto GenerateReturn
'==otherwise get last entry and add 1 onto number
Set entry = vcoll.GetLastEntry()
Set edoc=entry.document
WONum=edoc.WONumber(0)
WONumber=Right(WONum,Len(WONum)-2)
intWONumber=Cint(WONumber)
nextWONumber=intWONumber+1
'==Get length and pad with zeroes (4 digits max)
numlen=Len(Cstr(nextWONumber))
Select Case numlen
Case 1
	prefix="000"
Case 2
	prefix="00"
Case 3
	prefix="0"
Case Else
	prefix=""
End Select
nextnumber=prefix & Cstr(nextWONumber)
GenerateReturn:
'==string shortcode and new padded number together & write to doc
returncode=sstring & nextnumber
note.WONumber=returncode
Dim wodoc As NotesDocument
'-- Write WO Placeholder by using the "frmDelWONumber" form
Set wodoc=db.CreateDocument
wodoc.form="frmDelWONumber"
wodoc.WONumber=returncode
Call wodoc.Save(True,True)
’ Display message & “Done.”
alertmsg="The following number has been allocated to this Warehouse Delivery WO: " & returncode
Print "<script>alert(" & "'" & alertmsg &"'" & ")</script>"
Print "<script>location.href='vWhseOrders?OpenView'</script>"
Sub UpdateActivity(activitytag As String)
If debugCode=1 Then Msgbox "UpdateActivity"
currentUser=Evaluate(|@Name([CN];@UserName)|,note)
activityLog=note.ActivityLog
upperb=Ubound(activityLog)
Redim Preserve activityLog(upperb+1)
For n = (upperb+1) To 1 Step -1
	activityLog(n)=activityLog(n-1)
Next n
activityLog(0)=Format(Now(),"mm/dd/yyyy hh:mm:ss AM/PM") & " (" & currentUser(0) & ") - " & activitytag & "<BR>"
note.ActivityLog=activityLog
Sub logStatus
If note.CustomerDeliveryDate(0) <> "" Then
	status="Closed/Delivered to Customer"
	activitytag="Tracking: "  & status
Else
	status="Tracking"
	activitytag=status
Sub SendMail_Issuer(AlertType As String)
'-- Create Mailer with http link to notify Issuer that the WO form has been submitted
Dim maildoc As NotesDocument
Set maildoc=maildb.CreateDocument
'Set maildoc=db.CreateDocument
maildoc.form="Memo"
maildoc.DeliveryPriority="H"
maildoc.subject=MailSubject
maildoc.from="" &"""" & "" & docAuthor & "" & """" & " <" & currentUserEMail & ">"
Set bodyfield = New NotesRichTextItem(maildoc, "Body")
Call bodyfield.AddNewLine (2)
Call bodyfield.AppendText("Hello " & docAuthor & ",")
Call bodyfield.AppendText("This is to notify you that your WO has been submitted.")
Call bodyfield.AppendText(MailTag2)
Call bodyfield.AddNewLine (1)
Call bodyfield.AppendText ("http://corpnts1.corp.int/ccs/wo.nsf/fsmain!Open&Frame=fMid&Src=/WONumber/" & OriginalUNID & "!Open&Login")
'-- Save into the router mail.box
maildoc.Recipients=SendListAll
Call maildoc.Send(False,SendListAll)
Sub SendMail_WOGroup(AlertType As String)
'-- Create Mailer with http link to notify WO Group that the WO form has been submitted
maildoc.form="Memo"
Call bodyfield.AppendText("Hello,")
Call bodyfield.AppendText(MailTag)
Sub SendOrderClosedMail(AlertType As String)
maildoc.form="Memo"
'WOSendList(0)="wo@corp.com"
'WOSendList(1)=currentUserEMail
WOSendList(0)="wo@corp.com "
WOSendList(1)="me@corp.com"
maildoc.form="Memo"
maildoc.subject="Notice" & " : WO # " & WONum & " Closed "
'-- Send to WO Handlers
Call maildoc.Send(False,WOSendList)
Script Library (ErrorHandlingSL) code :
Function PrintErrorMsg(errMsg As String, fatal As Integer)
Print {
} & errMsg & {
Return
If fatal Then End
End Function
Subject: LS not working …help
There is no error but your code continues on into your errortrapping.
Just put exit sub above your error trapping like so:
Exit Sub
GenErr :
Print “
OOPS …
Exit Sub
Subject: RE: LS not working …help
Thank you Marian,that works for me.
Dan
