LS Evaluate problems
Hi!
I’ve searched the forum for similar problems and found quite a bit on the evaluate + @dbcolumn and the LS equivelant of @Max but still can’t get my code to work.
I’m trying to do a counter in the Querysave event that sets a unique number in the Phone-field, but need to do it in LS since the Continue flag doesn’t exist in Formula and I have to be able to halt the save if some conditions aren’t met.
The Formula code that works is as follows:
@If(!@IsNewDoc;
@Do(
NL := @DbColumn(“Notes”:“NoCache”;“”:“”;“($Num)”;1);
NLMax := @Max(@ToNumber(NL));
NT:=NLMax+1;
@SetField(“Phone”;@Text(NT))))
The LS code that don’t is:
Sub Querysave(Source As Notesuidocument, Continue As Variant)
Dim NL As Variant
Dim NLMax As Integer
Dim NT As Integer
NL = Evaluate({@DbColumn(“”;“”:“”;“($Num)”;1)})
NLMax = Evaluate({@Max(@Tonumber(NL))})
NT = NLMax+1
Call source.fieldSetText (“Phone”,Cstr(NT))
All I want to do is to check for the highest number in a column and set a field to the next number. I haven’t gotten to the @isnewdoc check yet since I got stuck on Evaluate.
Any help is appreciated!
Regards
Frank
Subject: LS Evaluate problems
NL := @DbColumn(“Notes”:“NoCache”;“”:“”;“($Num)”;1);NLMax := @Max(@ToNumber(NL));
NT:=NLMax+1;
You could use:
dim session as new notessession
Dim db as notesdatabase
Dim view As NotesView
dim number as double
Set view = db.GetView(“($Num)”)
number = view.AllEntries.Count
number=number+1
Hi
I’m quite sure that your formula doesn’t know what NL is.
Wouldn’t
NLMax = Evaluate({@Max(@Tonumber(@DbColumn(“”;“”:“”;“($Num)”;1)))})
work ?
Btw I’m don’t know if @tonumber works with a list…
HTH
Subject: Thank you
Hello Yannick and thank you for your response.
I managed to get the code to work the way I wanted with:
Dim NL As Variant
Dim NLMax As Long
NLMax = Clng(NL(0))+1
Call source.fieldSetText (“OfficePhoneNumber”,Cstr(NLMax))
This because the first column in the view ($Num) is sorted descending so the first value is always the largest (right?).
Now all I have to add is the @newdoc thing but that shouldn’t be too hard. =)
Thanks once again
Regards
Frank
