LS Agent not running on web
I have a form that has an action button to submit the document to be saved and launch an agent. The button has the following formula:FIELD Status:=“Submitted”;
@Do(
@Command([FileSave]);
@Command([FileCloseWindow]))
And the WebQuerySave event of the form has the following formula to launch the agent:
@Command([ToolsRunMacro]; “(SubmitWhseDelivery)”)
The problem is that the agent does not seem to be launched. Can anyone tell me what is wrong?
The “(SubmitWhseDelivery)” agent has the following LS code:
Sub Initialize
'== Submit Document Agent
'== Submits doc for web user
'-- Declarations & Instantiate
Set s = New NotesSession
Set db = s.CurrentDatabase
Set note = s.documentcontext
path=db.filepath
'-- set to 1 to debug via msgbox at server console
debugCode=0
'-- Get Doc fields
OriginalUNID = note.DocUnid(0)
’ SendList=note.NextUserEMail(0)
’ SendListAll=note.NextUserEMail
SendList="dlebrun@corp.com"
SendListAll="dlebrun@corp.com"
WONum=note.WONumber(0)
Division=note.Division(0)
JobNum=note.GPJobNumber(0)
Delivered = note.Delivered(0)
DeliveryDate=note.DeliveredDate(0)
docAuthor=Evaluate("@Name([CN];Author)",note)
'currentUser=docAuthor(0)
currentUserEMail=note.AuthorEMail(0)
partialflag=""
'-- Build logic for e-mail
st=note.Status(0)
note.DateSubmitted=Now
'-- Generate WO Number
If note.WONumber(0)="-Not Assigned-" Or note.WONumber(0)="" Then Call SetWONum(db,note)
activitytag=" Warehouse Order Submitted"
Call UpdateActivity(activitytag)
MailSubject= st & ": " & WONum
MailTag="This WO has just been submitted. " & Chr(13) & Chr(13) & "Please follow link to view submitted Warehouse Order :"
AlertType="Initial"
Call SendMail_WOGroup(AlertType)
Call SendMail_Issuer(AlertType)
'== CHECK STATUS
If debugCode=1 Then Msgbox st
Select Case st
Case "Draft"
	Exit Sub
Case "Submitted"
	AlertType="Initial"
	'Exit Sub  ' if status=submitted then no need to go further
	'-- look for *Cancelled* WOs and set flags/email --
Case "Cancelled"
	note.Status="Cancelled"
	note.DateCancelled=Now
	activitytag=" Cancelled WO"
	MailTag="This WO has been cancelled for the following reasons:" & Chr(13) & note.RejectReasons(0) & Chr(13) & Chr(13) & "Please follow link to view WO:"
	AlertType="Initial"
	'Exit Sub
End Select
	'-- Do the e-mail for order confirmation & arrived at warehouse
If partialflag <>"1" Then Call logStatus
	'=== if DeliveryDate field is set by Warehouse Mgr then send mailer to confirm
If DeliveryDate  <> "" Then
	activitytag=" Delivery Date established - Warehouse Delivery Order closed"
	MailTag="This WO has been delivered and closed." & Chr(13) & "Please follow link to view WO:"
	AlertType="Delivered/Closed"
	Call SendOrderClosedMail
	'=== End DeliveryDate Code
'-- If WO Number Required then generate one
MailSubject="Warehouse Delivery Order Form has been created for WO # " & WONum & "."
MailTag="Please follow the link to open/print the Warehouse Delivery Order form: "
AlertType="Delivery"
Subject: LS Agent not running on web
On Runtime check if the Target is set to “None” for agents that work on the current document. To know whether the agent is being run on the web, we can use the Print statement that displays a message in the current browser window. Put this statement before proceeding with your actual business logic.
Ex: Print “This LS Agent is Running on Web.”
