LotusScript "If" Help
The problem with this script is that it will create a response doc for the first if statement but not the second. There is a value in the Date2 fiels so the formula should continue.
Please Help!
Sub Initialize
Dim s As New notessession
Dim db As notesdatabase
Dim uiws As New notesuiworkspace
Dim mainDoc As notesdocument
Dim responseDoc As notesdocument
Dim Date1 As String
Dim Date2 As String
Dim i As Integer
Dim Lab As String
Set db = s.currentdatabase
Set responseDoc = db.createdocument
Set mainDoc uiws.currentdocument.document
If Lab1 = "Fab Ops" & Date1 <> "" Then
	Call responseDoc.makeresponse(mainDoc)
	responseDoc.form = "FO"
	responseDoc.Week = "W1"
	Call responseDoc.save(True,True)
If Lab1 = "Fab Ops" & Date2 <> "" Then
	responseDoc.Week = "W2"
Subject: You made my most common mistake!
You confused the formula language & for the LotusScript “and”
“&” in LS means to concatenate.
Howard
Subject: LotusScript “If” Help
You never created the second response document.
Try this:
dim uidoc as NotesUIDocument
set uidoc=ws.currentdocument
set MainDoc as NotesDocument
%REM
Not sure what you are doing with these
Dim Date1 As String
Dim Date2 As String
Dim i As Integer
Dim Lab As String
%ENDREM
If Lab1 = “Fab Ops” then
If Maindoc.Date1(0) <> “” Then
responseDoc.form = “FO”
responseDoc.Week = “W1”
If Maindoc.Date2(0) <> “” Then
responseDoc.Week = “W2”
else
exit sub
Try this:
%REM
Dim Date1 As String
Dim Date2 As String
Dim i As Integer
Dim Lab As String
%ENDREM
else
exit sub
Subject: Where are you setting the values for Lab1, Date1 and Date2? Your code does not show this.
It probably is executing the second set of statements. But you are not creating a second document there. So it is just executing the code against the same document you manipulated in the first block. I bet if you look at the one document that is created you will see that week = W2.
Good Luck,
Rob
