Hello
Has anyone encountered problems using the C API script to replace(refresh) design on a database that resides on a server from a client machine.
I am tying to replace design on a server database from a remote client, i retrieve the databases filepath using a mapped drive then pass it to the api call. The api cannot seem to find the database (Hdb returns as 0).
XXXXXXXXXXXXXX Call to the api XXXXXXXXXXXXXXXX
Sub Click(Source As Button)
Dim workspace As New notesuiworkspace
Dim session As New notesSession
Dim uidoc As NotesUIDocument
Dim Db As NotesDatabase
Set Db = session.CurrentDatabase
Set uidoc = workspace.currentdocument
Dim serverdir As String
serverdir = uidoc.fieldgettext("ServerDir") & "\" & db.filepath
Call ReplaceDesign(db.server, "Assets Template", "",serverdir)
XXXXXXXXXXXXXXXX API Code XXXXXXXXXXXXXXXXXXXXX
Option Public
Const wAPIModule = “NNOTES” ’ Windows
Const NSF_INFO_SIZE = 128
Const INFOPARSE_DESIGN = 3
Const NOTE_ID_ICON = &HFFFF0010
Declare Private Function DesignRefresh Lib wAPIModule Alias “DesignRefresh” _
( Byval S As String, Byval hDB As Long, Byval F As Long, Byval zA As Long, Byval zM As Long) As Integer
Declare Private Function OSPathNetConstruct Lib wAPIModule Alias “OSPathNetConstruct” _
( Byval zP As Long, Byval S As String, Byval F As String, Byval N As String) As Integer
Declare Private Function NSFDbInfoGet Lib wAPIModule Alias “NSFDbInfoGet” _
( Byval hDB As Long, Byval D As String) As Integer
Declare Private Sub NSFDbInfoModify Lib wAPIModule Alias “NSFDbInfoModify” _
( Byval S As String, Byval W As Integer, Byval D As String)
Declare Private Function NSFDbInfoSet Lib wAPIModule Alias “NSFDbInfoSet” _
Declare Private Function NSFDbOpen Lib wAPIModule Alias “NSFDbOpen” _
( Byval P As String, hDB As Long) As Integer
Declare Private Function NSFDbClose Lib wAPIModule Alias “NSFDbClose” _
( Byval hDB As Long) As Integer
Declare Private Function NSFItemSetText Lib wAPIModule Alias “NSFItemSetText” _
( Byval hNT As Long, Byval N As String, Byval D As String, Byval nD As Integer) As Integer
Declare Private Function NSFNoteOpen Lib wAPIModule Alias “NSFNoteOpen” _
( Byval hDB As Long, Byval NoteID As Long, Byval F As Integer, hNT As Long) As Integer
Declare Private Function NSFNoteClose Lib wAPIModule Alias “NSFNoteClose” _
( Byval hNT As Long) As Integer
Declare Private Function NSFNoteUpdate Lib wAPIModule Alias “NSFNoteUpdate” _
( Byval hNT As Long, Byval F As Integer) As Integer
Sub ReplaceDesign(templateserver$, templatename$, dbserver$, dbfilepath$)
dp$ = String(1024, " ")
OSPathNetConstruct 0, dbserver$, dbfilepath$, dp$
Dim hDB As Long
NSFDbOpen dp$, hDB
If hDB = 0 Then Exit Sub
d$ = Space(NSF_INFO_SIZE)
NSFDbInfoGet hDB, d$
NSFDbInfoModify d$, INFOPARSE_DESIGN, templatename$
NSFDbInfoSet hDB, d$
Dim hNT As Long
NSFNoteOpen hDB, NOTE_ID_ICON, 0, hNT
NSFItemSetText hNT, "$TITLE", d$, Instr(d$, Chr$(0))
NSFNoteUpdate hNT, 0
NSFNoteClose hNT
DesignRefresh templateserver$, hDB, 1, 0, 0
NSFDbClose hDB
