Strange issue when using datetime.adjustday changing the date format when running in a scheduled agent on a (new’ish) 8.5.1 server. I am in NZ and the date format is dd/mm/yyyy, and the server is displaying this format.
Here is an example (running 05 March 2010)…
Dim checkDate As New NotesDateTime(Today)
Print “CheckDate: " & checkDate.Lslocaltime ‘== this returns 5/3/2010, this is correct 5th of March
Call checkDate.AdjustDay(4)
Print “After adjust Day, CheckDate: " & checkDate.Lslocaltime ‘== this returns 5/7/2010 when it should be 9/3/2010 ARGHHH!!!
If I manually run the agent, the AdjustDay works as expected.
Regional settings on the server are correct.
Have found the Technote which states to change the registry entry “HKEY_USERS/DEFAULT/Control Panel/International/iDate” to “1 = D/M/Y” to fix the date format (this worked, server date is correct), but the bloody AdjustDay (and AdjustMonth) is changing the wrong value.
What am I missing???
I could really use some assistance here, as this is impacting on many applications (sending notifications, reminders, archiving records, etc).
Thanks in advance for any support.
Cheers!
