Lotuscript Problem - Help?
I have the following code that continually fails on this line:
Subject: Lotuscript Problem - Help ?
I haven’t run the code or anything but what is the value returned to text? Is it just a string or could it be a variant?
Also you set checktext = 0 ? Seems odd to me.
I personally would replace the evaluate with InStr( )
You should make some changes to your code:
checktext = Evaluate(|@Contains(“”, “Trace Complete”)|)->>>>this will return and variant array wit the 0 position equals to 0 i mean checktext(0)=0
Do Until checktext(0) = 1
text = Stream.ReadText()
checktext = Evaluate(|@Contains(“| & text & |”; “Trace Complete”)|) -->>> please notice that i have replaced your “,” by a “;” that is the correct one.
Sleep 1
Loop
Good luck
