Hello Designers!..
I need great help from you guys, I have a Database which supports only Lotus but not Web. Now i am planning to make same Database to support Lotus as well Web.
I need Simple Application Database which supports Lotus as well as web, I have searched in sandbox and others… but i didn’t found any application Database.
Please send me link, where i can find Simple Application Database which supports Lotus as well as web.
Thanks In advance,
Vj
Subject: Lotus → Web conversion…
It’s not that easy depending what you want to do.
Most notes forms will render in the web though not very well so quite often you will have 2 forms with the same alias. One for the web and one for notes but when you start looking at views, etc. it can become a bit tricky.
There’s plenty of articles/suggestions on here:
http://www-10.lotus.com/ldd/nd6forum.nsf/55c38d716d632d9b8525689b005ba1c0/74421aef33a3dbb58525733f006fdf9d?OpenDocument
etc…
