Lotus Traveler 8.5.2 - Device Primesync problem
Our Domino user “John Doe” has left the company, the users Apple device has been wiped and been set to Denied in lotustravler.nsf, Jon Doe has also been removed completely from Domino Directory and been put in the DenyAccessGroup.
I still get this error in console every 10 minutes:
Lotus Traveler: WARNING CN=John Doe/O=Acme User CN=John Doe/O=Acme on device primesync failed to login into the Lotus Notes Traveler Server. The user is using an invalid password or user ID.
Plese help me get rid of this error message/user.
I have restarted server and traveler several times, I have even added John Doe as not access server in the traveler tab in serverdocument (even though he no longer exist in DD)
In Lotustraveler.nsf view “Devices” john doe is Disconnected.
In Lotustraveler.nsf view “Users” john doe is Online. (this is very strange, everyone in this view is online even if I know they are not connected)
Thomas Adrian
http://www.notessidan.se
Subject: Lotus Traveler 8.5.2 - Device Primesync problem
did you delete the User from traveler=?
The command syntax for the deletion of users has been extended for version 8.5 of Lotus Traveler.
Use
‘Tell Traveler Delete ‘
instead of using
‘Tell Traveler Delete ‘,
whereas Device refers back to the Device ID of the mobile phone. It can be replaced by a * wild card, indicating all devices.
When using the delete command, bear in mind that the name of the user or device must not contain white spaces. Hence the short name of the user has to be used.
It is also important to note that the user to be manually removed from the Traveler database must exist in one of the directories of the Traveler server in order to resolve the short name.
Subject: delete
I can’t delete the user from lotustraveler.nsf using the delete command as the user is no longer in DD.
Subject: re: Lotus Traveler 8.5.2 - Device Primesync problem
The easiest way to stop this message is by deleting this user from the Traveler system. If you issue the command
Tell Traveler delete * CN=John Doe/O=Acme
The CN has be exact the same as it appear in the error message. This message should quick after 24 hours, if the problem still exist after the delete command. please collect the following information and create a PMR for this problem.
Data needed to investigate
  1. Tell Traveler log level finest
  2. What for the problem reproduce itself
  3. After the error message appears take a user dump with exact CN name. This may cause some error messages since the user is no longer in the names.nsf.
    • Tell Traveler dump CN=John Doe/O=Acme
  4. Collect data and send to IBM
    • Tell Traveler log collect
  5. Create a PMR and send the following data to IBM
    /IBM_TECHNICAL_SUPPORT/Traveler/logs
