I found this scirpt to forward mail to one of my users PDA I modified it to not allow for attachements to get forwarded. It works real well with one small issue: It marks the forwarded mail as read in the clients mail file. I just want the mail to forward without marking the mail as read. Could someone please read this over and let me know if you see why it isn’t working… I added this piece of code to the original to try and accomplish my task but it isn’t working : newmail.MarkUnread
Sub Initialize
On Error Resume Next
Dim session As New notessession
Dim maildb As notesdatabase
Set maildb = session.currentdatabase
Dim inbox As notesview
Set inbox = maildb.getview(“($Inbox)”)'get inbox
Call inbox.refresh 'refresh inbox to get newly arrived mails after this new mail
Dim newmail As notesdocument
Set newmail = inbox.getlastdocument’ get the last document
Dim flag As Integer
flag = 0
For i = 1 To 5 ’ check last five documents
If Not(newmail Is Nothing) Then
If newmail.myfwd(0) = “” Then ’ if it has not been forwarded
Set doc = New notesdocument(maildb)
doc.form = “Memo”
doc.SendTo = “mail@mail.ca” 'this should be changed to your e-mail
doc.Subject = "From : " & Left _
(newmail.from(0),12) & “Sub:” & _
newmail.Subject(0)& “”
'Forall item In newmail.Items 'check for attachments, if there - copy to new mail
'If (item.name = “$FILE”) Then
'Dim ritem As NotesRichTextItem
'Set ritem = New NotesRichTextItem _
'(doc, “Body”)
'Dim rtext As String
'Dim oritem As NotesRichTextItem
'Set oritem = newmail.GetFirstItem(“body”)
'Call ritem.AppendRTItem( oritem )
'rtext = oritem.getformattedText(False, 0)
'Call ritem.AppendText( rtext )
'flag = 1
'End If
If flag <> 1 Then
doc.body = newmail.body 'if no attachment then just copy the text
flag = 0
'End Forall
Call doc.send(False)'forward/send the mail
newmail.myfwd = “yes” 'flag the forwarded mail
newmail.MarkUnread
Call newmail.save(False,False,False) ’ save after flag
Set newmail = inbox.getprevdocument(newmail)
Next
