Lotus Script agents and web forms
I am accessing a SQL db via ODBC using a Lotus Script agent. I want to present the records through a browser. I can open the agent in the broswer (using ?OpenAgent) and get what I need but I want to be able to create my web forms then use computed text to call the agent from my page using:
@Command([RunAgent]; “TestAgent”)
However, the agent will not present the info.
Any ideas?
Subject: Lotus Script agents and web forms
You will need a placeholder for the data on your form. Create fields on the web form, then use documentcontext to access thos placeholders and assign the values from the output of your agent. Call the agent from the WebQueryOpen form event or call it from a button (@Command([ToolsRunMacro]; “”))
Get a sessiondoc handle:
Dim db As NotesDatabase
Dim sesdoc As NotesDocument
Dim item As NotesItem
Set sesdoc = session.DocumentContext
getvalue=sesdoc.GetItemValue( “webfield” )
Set item =doc.ReplaceItemValue_
“webfield”, “Hello”) 'this could also be the output of your agent
Hope this helps
