I just upgraded my display graphics card to NVidia/GeForce FX 5200 PCI which supports dual monitors. As a result, Lotus Notes client (7.0) starts/loads extremely slow with some frames not showing. Any ideas out there in Lotus Land?
All responses are appreciated. Thanks in advance.
Subject: Lotus Notes Client - Load Display Issue
I have upgraded the system BIOS using a Dell software patch (for Dell 350 Workstation). Checked settings within the BIOS.
The system OS is WindowsXP with 1GIG of RAM and plenty of hard diskspace.
At this point, the issue is unresolved. Any ideas?
Hi
Did you make sure you had the final latest drivers? I had a client with a similar problem and I had to dig far to get the latest drivers.
So maybe a second look is an option.
At the same time, when was the last time you upgraded your BIOS? I know this alone helped solve quite a few problems between the monitor and the mouse drivers
jacques
