Hi,I am working on Lotus Notes 8.5. i developed an application in java which parse the lotus email by using Domino Lotus 8.5 API. i successfully parsing the emails but still facing same problem when is email contains image and formatted text.Whenever, i tried to get the email message than it doesn’t shows image but displays text without formatting (dont show color,style)…
here is my code…
RichTextItem bodyText = (RichTextItem) d.getFirstItem(“Body”)
return bodyText.geUNFormattedText();
I also used return bodyText.getFormattedText(true, 20, 0); but still face same problem…
Can i anybody help me on this problem…
Regards,
Zaghman Arshad
Subject: Sorry but these functions just get the content as text/string
The methods you mention just get the text representation of the rich text field. Rich content like images and / or attachments are stripped. You could export the item as DXL. This does include images and attachments but DXL needs further processing.
Subject: Lotus Note v8.5 Image and Formatted text problem
Thanks Heini Schwammerl…is it possible to get formatted text i.e color,font etc using DXL?..
thanks in advance
Zaghman Arshad
Subject: Well yes and No
Well DXL will give you an XML interpretation of a Notes Rich Text item. It includes most formatting like colors and font size aso. but you have to translate it to get a proper output.
