Lotus Domino 9.0.1 Fix Pack 4 Install problem!
Just loaded Fix Pack 4 on W64 server. Install went fine with no errors but when the server starts it still shows FP3 which was the previous install.
“show server” command also shows FP 3.
Anyone seen this?..IBM ??
Subject: Have a look at upgrade.log
It should be in the program directory (e.g. c:\IBM\Domino), and it contains a record of each upgrade attempted since the first install. Search for the following:
Upgrade started at 11:12:14 Jun 19 2015 in C:\IBM\Installs.
Release 9.0.1FP3|January 12, 2015
DetermineMode: destination version Release 9.0.1FP4|June 07, 2015
Notes has been successfully upgraded.
There will be hundreds of lines between the “DetermineMode…” and “Notes has been successfully upgraded” lines that show the files being replaced. Odds are there will be some kind of indication there that the install didn’t succeed. This assumes it’s not something like rolling back to a prior snapshot on a virtual machine.
Subject: Rerun installation of FP4
Thanks for your response Chad.
I stopped all backup agents as well as virus checkers and reran the install. It completed successful and gave me a message at the end saying “Updating patch information”".
Looks good to go now.
:wink:
Subject: Thanks folks. We also confirmed 901FP4 is good. <>
downloaded, installed, it is 901FP4. Must have been a running program that had a handle to files and thus could not be upgraded.
