Lotus Connection problem from Notes client
While connecting from a browser to the Lotus Connections server works well, it doesnt seem to work from the client using the Notes Connections plugin.
If you install the plugin and fill in the url to the WAS server, and then select a document say to dogear you get:
1.The correct popup window to fill in description
2.After clicking ok, you “an error occurred…” which is pretty generic.
Anyone have this working?
SUpport says it is working only for the basic client
tx
