Lotus 8.5 beta 2 uninstall in Ubuntu 8.04 problem
I was install lotus 8.5 beta 2 on my linux Ubuntu 8.04. I was next, unistall them due a problem intra Lotus and Sinphony application.But i can’t uninstall Lotus, the error message is:
P.S. i try both with my user, with root
master@master-u-80:/$ sudo /opt/ibm/lotus/notes/internal_uninst
[sudo] password for master:
sudo: /opt/ibm/lotus/notes/internal_uninst: command not found
master@master-u-80:/$ sudo /opt/ibm/lotus/notes/internal_uninst/uninstall.sh
rm: cannot remove `/home/master/.local/share/applications/notesplugin.desktop’: No such file or directory
rm: cannot remove `/home/master/.local/share/mime/packages/notes.xml’: No such file or directory
Could not parse file ‘/home/master/.local/share/applications/pcs2.desktop’: Key file does not start with a group
Note that ‘/home/master/.local/share’ is not in the search path
set by the XDG_DATA_HOME and XDG_DATA_DIRS
environment variables, so applications may not
be able to find it until you set them. The
directories currently searched are:
  • /root/.local/share
  • /usr/local/share/
  • /usr/share/
gtk-update-icon-cache: Cache file created successfully.
I/O warning : failed to load external entity “/internal_uninst/notes.schemas”
Failed to open `/internal_uninst/notes.schemas’: No such file or directory
rm: cannot remove `/internal_uninst/notes.schemas’: No such file or directory
