Looping Help
I’m not sure if this is a looping error or something else, but…
I am trying to create an agent that will present the user with a dialog box and upon the selection from the dialog box, append the selection to a field on the document. I am just testing my code at the moment, but see below for an example. It returns the dialogbox values ok, and also returns the value from a field on the document ok (Liaison Branches). However when I try to append the value from the text list to a field on the document (Doc.LiaisonBranches), it doesn’t seem to do anything! Can anyone advise?
Sub Initialize
Dim s As New NotesSession
Dim db As NotesDatabase
Dim docCollection As NotesDocumentCollection
Dim doc As NotesDocument
Dim ws As New NotesUiWorkSpace
Dim tempdoc As NotesDocument
Dim item As NotesItem
Set db = s.CurrentDatabase
Set docCollection = db.UnprocessedDocuments
Set doc = docCollection.GetFirstDocument
Set tempdoc = db.CreateDocument
tempdoc.form = "CheckboxRetickDialog"
Set item = doc.GetFirstItem( "Approvals" )
Call ws.Dialogbox("CheckboxRetickDialog", True,True, False, False, False, False, "Select", tempdoc)
Forall values In tempdoc.SubmissionSelection
	If values = "Liaison Branch" Then
		Messagebox Values
		Messagebox Doc.LiaisonBranches(0)
		Call item.AppendToTextList("Liaison Branch: " + Doc.LiaisonBranches(0))
	Else
		Messagebox "Something else"
End Forall
Subject: Looping Help
Please disregard, I forgot to add a doc.save!!
