Hi all,
Is it possible to lock a document using a specific code such that when userA edits a document, userB cannot edit the same document untill userA release the lock?
If this is possible, would u mind if u can drop a hint or 2 on how to do that?
Many thanx in advance.
Best Regards,
Hengshi
Subject: Locked Document using codes
Dear
have a look on the $writers and $writersDate fields for the same
Mike
Subject: RE: Locked Document using codes
you can use “Allow document locking” database property and than can use Notesdocument.Lock(users) method provided in lotus script.
thanx all for the responses.
Regards,
hengshi
