Location Document Problem
In Location Documents, the Internet Mail Address field contains the address in “Bill Jones” bjones@xyz.com format.
The address keeps reverting to bjones@xyz.com.
The phrase gets changed back. Can’t figure out why its doing this. Can anyone help? or have you seen this problem before?
Regards,
Subject: Location Document Problem
Did the reply solve your problem?I am dealing with the same issue on Notes Client 6.5.4
Configuration Settings / MIME / Advanced / Advanced Outbound Message Options
RFC822 phrase handling
Subject: RE: Location Document Problem
In your location doc, you can go to Actions->Advanced and there is setting to keep the server from updating the location file email info.
