Local (not connected) address lookup does not work
Win2000 /notes6.51.The address lookup in local mode on the replica of the Public Address Bookdoes not work.
!It works fine on his personnal address book.
In connected mode it works fine.
The User Preferences / Mail ar correctly set with the two file names: personnal and replica of public.
The location doc seems fine as the lookup works with the personnal address book!
Thankss
Christophe
Subject: Local (not connected) address lookup does not work
When the user clicks on the “Address” button, isn’t there a choice for the replica of the Domino Directory on the local machine? It may not be what you are looking for, but the user can always select the name that way.
Gregg
Subject: RE: Local (not connected) address lookup does not work
If you are sure that the mail preferences listing the local address books is correct (names.nsf, xxxxxxx.nsf) and the location document is setup correctly, I would try replacing the location documents in the personal name and address book. You can copy them from any other address book that this feature is working correctly on (in other words, if your client does NOT have this issue, use the location documents from your Pnab and edit the necessary user info for the user who is having this issue). Then try it. If that doesn’t solve the problem, try refreshing/replacing the design on the mail database.
