Load catalog problem
Hi
I can no longer run the “load catalog” command. The error that I get is:
17.11.2008 14:41:33 Unable to update catalog: Remote pathname must be relative to Data Directory
I have searched the forums but nobody seems to have had this problem.
I am not sure when this started happening but I have recently upgraded from Domino 7.0.3 → 8.0.2. I have also decommissioned a server just last week.
I assume the message refers to the “old” Domino server.
I have deleted and created a new catalog.nsf → the problem still exists!
Thanking you in advance for any help given
Ursus Schneider
Subject: Places to check
Check the server document, Server Tasks tab, Domain catalog tab. Eventually the next Index catalog tab if available.
Check the LocalDomainCatalogServers group in the NAB.
Check the ini file, if anything seems obsolete.
I can’t think of any other place where you could find other parameters for the Catalog task.
Subject: Solved!
Hi Fabrice
Thank you very much for taking the time to answer my questions - I disabled the domain catalog and now “load catalog” is working :o)
Oh happy days…
Thank you again, I’ll get round to checking the problem with the domain catalog at a later stage (was only testing it anyways :o)
