Link-problem
Hi.I have a database with documents that containes links to othet docs in the same databse, ordinary doclinks. When the documents are archived, copied to another database on the same server, the links points to docs in the archiveDB!??
If I look at the link-properties I can see that the replica-id of the link has changed to the archiveDB:s ID.
The archiving is done in script and the docs are copied with the CopyToDatabase-command.
Anyone that have had the same problem? And maybe solved it…:slight_smile:
Thanks in advance
Jocke
Subject: Link-problem
Are you looking at the doclink properties in the original database? Or the archive? There is a small program named: SetRep that can change the replica id of a Notes database to whatever you need it to be. I would attach it here for you, but am not allowed to do attachments in this database. But, it can easily be found.
Subject: RE: Link-problem
Hi Rick.The problem is that the replica id in the doclink is changed.
I don’t want to change the replica id of the database, I want the replica id in the doclink to be the same in archiveDB as in the original DB.
/Jocke
