Letter formatting problem
My query is : Basically this application generates MS Word letters by making use of a Third Party product named Intelli-print. The format of these letters is not good.
Example :
Dear Mr Ravi
I refer to your conversation/letter of/dated ….. which is now receiving our attention.
I am sorry you have found the need to raise a complaint with the Bank. My understanding
of the issues you have mentioned are as follows:
The points you have raised in your conversation/letter will be investigated by one of our
complaint handlers who will write to you when the investigation is complete.
The Financial Services Authority requires me to explain that after four weeks we shall
inform you in writing of the progress of your complaint. However if the investigation is not
complete within two months we will write to you again setting out the action available to
you.
I have enclosed for your information a copy of the Bank’s Complaints procedure
‘Addressing your Complaint’.  The enclosed brochure explains how to pursue your
complaint within the Bank if you remain dissatisfied; and how to refer your complaint to
the Financial Ombudsman Service if the bank cannot resolve the complaint to your
satisfaction.
We will be in touch in due course.
Yours sincerely
Ravi
Complaints Manager - Insurance
Agent Name : Process Mail Merge :
Options :
Option Public
Option Declare
Use “LibMailMerge”
Sub Initialize
' Author:				Unknown
' Creation Date:	Uinknown
' Revisions:
' 29-Jun-2007		0001		CJS	Bug fix as a result of NAGs SP2 build.
' Description:
Dim ws As New notesUIWorkspace                          ' Obtain Front- end object
Dim session As New notesSession                            ' Obtain Back-end object
Dim db As NotesDatabase
Dim dcSelected As notesDocumentCollection           'Collection of documents for processing from view
On Error Goto errSub
Set db = session.currentDatabase
 ' Check for IntelliPRINT
If Not checkIntelliPRINT() Then
      'Not found - Display error msg...
	Messagebox "An IntelliPRINT installation is required to execute this feature and it is not installed in this system. Cannot proceed.", 0, db.Title
	Exit Sub
Set dcSelected = db.UnprocessedDocuments
Call executeMailMerge(dcSelected)
Exit Sub
errSub:
Msgbox Erl & " : " & Err & " - " & Error$
Exit Sub
Script library name : Execute Mail Merge :
Function executeMailMerge(dcContacts As NotesDocumentCollection) As Integer
Const PARAM_MSG_SLDIALOG = "Select standard letter"
Const PARAM_FORM_DLGMAILER = "DlgMailer"
Const FLD_UNID = "UNID"
Dim CurrentNote As NotesDocument                         'Temporary document for dynamic user input
Dim ContactNote As notesDocument                         'Selected person document
Dim MailerNote As notesDocument                            'Selected mailer document
Dim IHandle As Long                                                 ' IntelliPRINT variables
Dim szID As String
Dim strFilePath As String
Dim iCount As Integer
Dim lnReturn As Long
On Error Goto errFunction
executeMailMerge = False
If dcContacts.Count = PARAM_ZERO Then
	Messagebox "No documents selected for mail merge. Cannot proceed.", 0, db.Title
	Exit Function
	Exit Function
Set CurrentNote = New NotesDocument(db)            'Create temporary document for dialog box function
If Not ws.DialogBox( PARAM_FORM_DLGMAILER, True, True, False, False, False, False, PARAM_MSG_SLDIALOG, CurrentNote ) Then
	Exit Function
If CurrentNote.GetItemValue(FLD_UNID)(0) = "" Then              'User made no selection
	Msgbox "No mailer is selected from the list", MB_ICONINFORMATION,"IntelliPRINT"
	Exit Function
Set MailerNote = db.getDocumentByUNID(CurrentNote.GetItemValue(FLD_UNID)(0))     'Obtain mailer doc selected by user
Set ContactNote = dcContacts.getFirstDocument
While Not ContactNote Is Nothing
	Call UpdateDoc(ContactNote, MailerNote)                                                        ' Merge mailer fields
	szid = szid + ContactNote.noteid + ";"                                                 ' Set string of noteids for IntelliPRINT call
	Set ContactNote = dcContacts.getNextDocument(ContactNote)
Wend
’ IntelliPRINT processing
IHandle = IPSInitialize(db.Server, db.FilePath, PARAM_VIEW_NAME)   'Initialize IntelliPrint and get its Handle
Call IPSOpenFormat (IHandle,PARAM_FORMATNAME,  0 , "", "")                 'Open  format
 ' Generate the automated filename for the rtf file to be exported
strFilePath = Session.GetEnvironmentString("Directory", True) + "\TempLetter.rtf"
 ' Export the mail merged letter to a rtf file
lnReturn =  IPSExport(IHandle, szID, strFilePath, 8)
'-----------------------------------------------------OLD Code
’ iCount = 1
’ Do
’ strFilePath = Session.GetEnvironmentString(“Directory”, True) + “\Letters” & iCount & “.rtf”
’ iCount = iCount + 1
’ Loop Until Dir$(strFilePath) = “”
’ lnReturn = IPSExport(IHandle, szID, strFilePath, 8)
Call IPSCloseFormat(IHandle)         'Close the format
Call IPSTerminate (IHandle)            'Terminate IP
 'Remove fields added for mail merge
	Call RestoreDoc(ContactNote, MailerNote.Subject(0))                                       'Remove merged fields
	Set ContactNote = dcContacts.GetNextDocument(ContactNote)
Wend
Call OpenFileinWord(strFilePath)
executeMailMerge = True
Exit Function
errFunction:
Msgbox Erl & " - " & Err & " : " + Error$
Exit Function
End Function
Check Intelii print :
Function checkIntelliPRINT() As Integer
Dim strIPFile As String
strIPFile = "NIPRINT.dll"      ' IntelliPRINT core dll
If Dir$(strIPFile) = "" Then       ' Check whether the core dll is installed in notes program folder and set the flag accordingly.
	checkIntelliPRINT = False
Else
	checkIntelliPRINT = True
End Function
Update docs:
Sub updateDoc (pdoc As notesDocument, mailerDoc As notesDocument)
’ Add Body fields
pdoc.Body = mailerDoc.LetterBody(0)
pdoc.TodayString = Format$(Today,"dd mmmm yyyy")
Call pdoc.Save( False, True )
Restore Doc’s
Sub restoreDoc (pDoc As notesDocument, Byval strMailSubject As String)
Dim Session As New NotesSession
Dim strLog As String
Dim vLog As Variant
'Remove Body and Salutation
pdoc.removeItem("Body")
pdoc.removeItem("TodayString")
 ' Update Case Management Log
strLog = strMailSubject + " CREATED - ( " + Session.CommonUserName + " "  & Now & " ) "
vLog = pdoc.GetItemValue("dispLetterInfo")
Redim Preserve vLog(Ubound(vLog) + 1)
vLog(Ubound(vLog)) = strLog
pdoc.dispLetterInfo = vLog
 ' Save document
Open Fileword:
Sub openFileinWord(strFilePath)
Const PARAM_WINDOW_NORMAL = 0
Const PARAM_WINDOW_MAXIMIZE = 1
Dim MyWord As Variant
 ' Open the exported rtf file in MS Word
Set Myword = CreateObject("Word.Application")
Myword.visible = True
If Myword.Application.WindowState = PARAM_WINDOW_NORMAL Then
	Myword.Application.WindowState = PARAM_WINDOW_MAXIMIZE
Myword.Documents.Open strFilePath
Functions – Set Notes Program :
getNotesdir:
Function getNotesDir() As String
Dim sBuffer As String
Dim sChar As String
Dim sDir As String
Dim nIndex As Integer
Dim bExit As Integer
Const MAX_LEN = 127
sBuffer = String$(MAX_LEN, 0)
Call OSGetExecutableDirectory(sBuffer)
nIndex = 1
sDir = ""
bExit = False
While Not bExit
	sChar = Mid$(sBuffer, nIndex, 1)
	If nIndex <= MAX_LEN And sChar <> Chr$(0) Then
		sDir = sDir + sChar
		nIndex = nIndex + 1
	Else
		bExit = True
Wend
GetNotesDir = sDir
End Function
Sub setNotesProgramDirectory()
Dim sDir As String
sDir = getNotesDir()
Chdrive Left$(sDir, 1)
Chdir sDir
setNotesProgramDirectory :
Dim sDir As String
Chdir sDir
I need this type of format.
Ref : GCI/21344 12thNov2007,
												Bangalore.
Mr.T.Sangha,
17,Bangalore,
UK.
Dear T Sangha2,
I refer to your conversation/letter of/dated which is now receiving our attention. I am sorry you have found the need to raise a complaint with the Bank. My Understanding if the issues you have mentioned are as follows :The points you have raised in your conversation/letter will be investigated by one of our Complaint handlers who will write to you when the investigation is complete.
The Financial Services Authority requires me to explain that after four weeks we shall  inform you in writing of the progress of your complaint. However if the investigation is not complete within two months we will write to you again setting out the action available to you I have enclosed for your information a copy of the Bank’s Complaints
procedure Addressing your Complaint.The enclosed brochure explains how to pursue your complaint within the Bank if you remain dissatisfied; and how to refer your complaint to the Financial Ombudsman Service if the bank cannot resolve the complaint to your satisfaction. We will be in touch in due course.
The Financial Services Authority requires me to explain that after four weeks we shall inform you in writing of the progress of your complaint. However if the investigation is not complete within two months we will write to you again setting out the action available to you I have enclosed for your information a copy of the Bank’s Complaints procedure Addressing your Complaint’. The enclosed brochure explains how to pursue your complaint within the Bank if you remain dissatisfied; and how to refer your complaint to the Financial Ombudsman Service if the bank cannot resolve the complaint to your satisfaction. We will be in touch in due course.
Yours sincerely
Ravi
General Manager - Insurance
Subject: letter formatting problem
I hate to simply suggest a different third party product, but why don’t you try a free evaluation of our Midas Rich Text LSX, which is known for its rendering capabilities? If it doesn’t do a far better job, don’t bother to buy it.
On the other hand, nothing you are doing sounds like it should require much, so it is hard to see why Intelliprint doesn’t work in this scenario. You should raise the issue with Intelliprint support, I would imagine.
