Domino as LDAP for third party system works perfect on Port 389, BUT:
If i’m trying to use 636, client throws this error:
Problem with RootDSE-Content
Problem occurs in loading entry RootDSE from host.domain.com:636
The LDAP Server uses an official certificate which is valid.
What can i do ?
Uwe
Subject: LDAP with SSL Port 636
In order for ldapsearch to work over SSL (port 636), the Domino Directory (names.nsf) must have the Certificate Authority (CA) included
in the trusted certificates. When using ldapsearch.exe from the Lotus Notes client, follow the steps outlined in the following technote
Title: How to retrieve an Internet Cross Certificate using Lotus Notes 6
Doc #: 1108117
URL: http://www.ibm.com/support/docview.wss?uid=swg21108117 http://www.ibm.com/support/docview.wss?uid=swg21108117
Also do a “show tasks” at the command prompt and see if the ldap task
is running?
hcl-bot
October 31, 2014, 10:02am
3
Subject: listening on…
the Show Tasks will not only confirm that LDAP is running
but listening on the expected ports 389, 636
Subject: Status
sorry for the late response …
sh tasks shows as expected:
LDAP Server Listen for connect requests on TCP Port:389 SSL Port:636
ldapsearch comes not from notesclient. I’m using it from a third party linux machine.
Tom, i don’t know how to add a new CA certificate to the Domino dirctory.
There is a button ‘Add’ but i can only puttin some text but no keyfile.
